My ds started to make a death sequel at 6000rpm
Old Jun 25, 2010 | 11:09 AM
bronson350warrior's Avatar
Default My ds started to make a death sequel at 6000rpm
My ds started to make a death sequel at 6000rpm and on at that rpm I don’t know what’s wrong the only thing ive don is put a quitter exhaust on and changed the coolant some one pleas help
Old Jun 25, 2010 | 08:07 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
clutch belt squeals like a pig on my outty 800- I replaced it with another one from ebay and it still does it- I brought it to the dealer to check the cvt and they said it's because I used an aftermarket belt- not a BRP OEM belt.
I don't know what the diff is but when BRP wants $174 for a belt and I can get one on ebay for $65 that seems to work fine- ebay wins.
so, my point (eventually got to it ) is that maybe you need a belt...?
edit: actually- sorry, I have no idea if a ds even has a cvt trans
Old Jun 25, 2010 | 09:25 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
Talking
just put some pancake syrup on the sides of the drive belt it stops the sqealling and smells good, makes ya hungry I personally like blue berry
need a little more infro on the ds, did it start losing power when the noise appeared?
if you changed the head pipe check for an exhaust leak at the head it will make a whisle.
where is the noise coming from, top of motor or bottem?
take your oil filter out and see if it is full of brass colored metal if it does you have bearing trouble put the bike on a stand and rev it up isolate the noise
Old Jun 25, 2010 | 10:16 PM
the squeal is in the top end (cylinder or head) the pipe is a ronwoods (just changed the packing) it has normal power and the pipe is tight the noise only happens at 6grand
Old Jun 25, 2010 | 10:35 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
It's that damned quieter exhaust that you put on. Put that loud azzed exhaust back on there and I bet the squeal goes away!
Have you checked the hose connecting the carb to the intake? They do dry rot from time to time and need to be replaced. Could be air sucking in somewhere that needs a little maintenance/TLC.
Old Jun 26, 2010 | 05:14 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
well- I do know that when a bearing starts to go on a vehicle you'll get a squeal at higher rpm- be it a crank bearing, wheel bearing or a muffler bearing
(no- seriously )
Old Jun 26, 2010 | 02:06 PM
DSengineer's Avatar
Has been here a long time!
No CVT belt on a DS. I would start by draining the oil from the bottom end and look for any metal shavings. Does it squeal only under load or also sitting in neutral?
Old Jun 26, 2010 | 10:57 PM
it squeals at 6000rpm in neutral with no load im going to cheack the oil monday i did notice a squeal at 4000rpm with a load but is verry faint (can only hear it with the helmet off)
Old Jun 27, 2010 | 12:08 PM
checked the oil to day and just started cussing. The oil was black and thin with large (1/4 inch in size) metal flakes in it the oil filter was clogged and had some more (2or3)1/4in flakes in it what doi do now?
Old Jun 27, 2010 | 01:09 PM
maniacdriver's Avatar
Get out your billfold, its going to get expensive. Start by pulling off clutch cover and then the head if nothing abnormal in clutch. If the valve train and piston are ok pull other side cover but cases will probably have to be split.
