Warn winch help
Old Jul 14, 2010 | 10:34 PM
jgroesbeck's Avatar
Default Warn winch help
Hey Guys,
Looking for a little help installing a WARN XT25 on my 2010’ Polaris 550XP. I’ve done pretty well thus far, but have one question regarding the wires coming off the rocker switch. No issues with the two large connections, as I know they attach to the contactor, mounted on the frame near the radiator. My main question is where to splice the 20g red wire coming off of the wires coming out of the rocker switch?
The book says to “Splice the end of the red 20ga wire to a key controlled, fused, accessory circuit (powerpoint) of the ATV (use the provided wire splice). Using a test light, locate a suitable wire from the ATV key switch. The wire should only have power when the key is in the "ON" position.”
There are four wires coming out of the ignition piece that are colored 1. red/white 2. red/black 3. orange and 4. white/red. Looking at a wire diagram in a service manual, I would guess that either the red/white, red/black, or orange wire will work. Can anyone confirm this for me?
Also, when it comes to splicing, I intend to splice both wires together right next to the ignition piece. Are there any issues with splicing it there?
Appreciate the help gents J
Cheers,
JG
Old Jul 14, 2010 | 10:58 PM
chuck_raduenz's Avatar
i do not have an xp. but the orange wire sounds like the correct wire to splice on. iv also read on prior posts that there should be a wire or 2 that are termanation with a wire connector female end thats under the headlight pod. thats what id connect to. and that what i connected to on my 08 sp 500.
Old Jul 15, 2010 | 12:25 AM
jgroesbeck's Avatar
I read something similiar as well but can't find the wire connectors under the pod. I'll take another look in the morning. Thanks for the reply!
JG
Old Jul 15, 2010 | 01:56 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just find a wire that has power when the key is turned on like the acess. plug(i think orange on some older bikes like mentined) and hook into that for pwoer.
Old Jul 16, 2010 | 12:49 AM
jgroesbeck's Avatar
Thanks for the inputs guys... got er done tonight with little hassle. Now it's time to go out and use it
Old Jul 16, 2010 | 09:39 AM
hallj86's Avatar
xp have the connector for the switch they are wired for the winch already.
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
