Warn winch problem
Old Jul 16, 2010 | 06:39 PM
tydogg's Avatar
Default Warn winch problem
I have a 2500 warn on my Vinson and has always worked good. Mainly used for plowing snow, but the other day i was using it to pull a light load and I got off the quad to hook onto a new spot and the handle bar switch was now backwards out for in and in to run line out ? The winch also does not have enough power now to pull the quad with the brakes on like it should. What is the problem likely to be, burnt motor, contractor ?
Old Aug 4, 2010 | 01:55 PM
Montana Jacks ATV Outpost's Avatar
Sounds like the contactor went bad. Check all your connections too, for corrosion or loose fittings.
Old Aug 4, 2010 | 02:41 PM
TLC's Avatar
TLC
There was a recall on Warn 2500-3500 8 post connectors.WARN Part Number 62135.A0)
SOLD BETWEEN MAY, 2001 AND SEPTEMBER 1, 2005
Warn Industries - 2006 Recall And Replacement Notice: Contactor
Old Jun 30, 2011 | 01:45 PM
APappa's Avatar
http://www.sportsmansguide.com/net/cb/cb.aspx?a=692742"] this[/url] is my winch, super strong. i usually use it for pulling up stumps around my yard but for what it is its a great price
Old Jun 30, 2011 | 01:46 PM
APappa's Avatar
this is the winch i use, super strong. i usually use it for pulling up stumps around my yard but for what it is its a great price
Grip - On Tools 3,000 - Lb. Atv Winch, Atv, Grip, Grip-On Tools 3000 Lb Atv Winch Waterproof Control Box at Sportsman's Guide
toonces
Oct 19, 2015 02:21 AM
Bratman2
Jul 23, 2015 12:36 PM
Gtsordo
Jul 22, 2015 01:27 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
