skipping
Old Jul 16, 2010 | 09:45 PM
chinqmasta's Avatar
Question skipping
i have a 2004 sportsman 700 EFI. recently began skipping or bogging down when given throttle. when brought back to idle it will skip for a while and then resume normal operation. i have replaced the twin coil pack, plug wires, and plugs. still same problem. i can unplug the left plug wire and skipping continues. if i unplug the right wire instead of the left the engine dies. any suggestions, i had a ride planned in a week and thought the new coil etc. would fix my issue
Old Jul 17, 2010 | 04:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
when you unplugged the plug wire and it was still skipping did you check to see if the plug was firing? did you replace the plug cap when you rplaced the wires? sometimes caps willl do that.
Old Jul 17, 2010 | 02:43 PM
chinqmasta's Avatar
yes it was firing, and aren't the caps built onto the plug wires?
Old Jul 17, 2010 | 04:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
w/out looking i 'm not sure. if they will unscrew then you can replace them. did you replace them w/ the new wires?
Old Jul 17, 2010 | 04:34 PM
chinqmasta's Avatar
replaced the whole plug wire assembly....from the coil to the plug. the old coil did not seem to be putting out enough fire so we thought the coil pack was getting weak
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Minimod
Sep 10, 2015 08:03 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
black_thunder
Sep 6, 2015 04:41 PM
TLC
Jul 25, 2015 02:24 AM
