05 Outlander Voltage Regulator?
Old Jul 20, 2010 | 10:29 AM
IAFF's Avatar
Default 05 Outlander Voltage Regulator?
I have a 2005 Outlander Max 400.
I'm getting the dreaded FAIL message and the lights are dimming at idle. I assume it's the vr, I will check the voltage output this week. I did recently replace the factroy battery with an Exide 20L-BS.
I called the local dealer about parts, said they would run a diagnostic on it when they have time.
The part they are showing to replace this is a $451 amplifier box, part # 420664285. Does anybody know of a much cheaper after market replacement part for this?
Old Jun 15, 2011 | 11:50 AM
frozeninminnesota's Avatar
Im having the same issue, no spark and they are telling me its the Amplifyer box. Did you ever find a cheaper or aftermarket verison of this ?? Please let me know..
Thanks
Pete
Old Jun 15, 2011 | 12:03 PM
IAFF's Avatar
That seems like it's been longer ago than last summer. I'm pretty sure I got a new voltage regulator fromm ebay. I'll chek my history there and see what I find.
Old Jun 15, 2011 | 12:13 PM
IAFF's Avatar
I bought a voltage regulator/rectifier from a dealer called rmstatorinc for about $70 on ebay. It was a plug in unit, took just a few minutes to replace.
It was like this one, not sure about interchangablility from year to year though. Good luck.
Can-Am OUTLANDER 400 Voltage Regulator Rectifier 2003 | eBay
Old Jun 15, 2011 | 12:24 PM
Looks like we have the exact same machine. I have a 2005 Outlander 400 MAX.
The mechanic says the CDI box is bad but I don't want to pay 525.00 to BRP... So im kinda looking for an alternative.
It didn't show a direct cross so I emailed them. Hopefully get an answer soon..
Old Jun 15, 2011 | 12:46 PM
IAFF's Avatar
If what your mechanic is calling the CDI box is the black box mounted next to the battery with 1 wiring harness coming off of it, that should be the same as thing as a rectifier. I'm pretty sure that will be the same as the one listed for sale. Hopefully the seller replies with that news for you.
Old Jun 15, 2011 | 12:55 PM
Nope, not the same. The CDI box is located in the front of the ATV, it looks like its attached to the main harness, but i called RMSTATOR in canada and they said its completely different. .. So im continuing to call the salvage yards .... otherwise BRP gets another 500 dollars from me.
I wish some of these places would get up and make some aftermarket parts for these machines. It gets a bid old having to put OEM parts in all the time when you can't find them online.
Old Jun 15, 2011 | 01:14 PM
IAFF's Avatar
Ouch, that hurts. Post the info if you find a cheaper alternative.
Good luck.
Old Jun 23, 2011 | 04:23 PM
Good luck.
Nope.. Ended up giving BRP more of my money...
Joe454
Nov 20, 2020 01:19 PM
Gwolf228
Feb 18, 2017 01:36 AM
bigred20653
Oct 2, 2015 10:05 AM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
