07 Can am outlander ?'s
Old Jul 27, 2010 | 07:27 PM
stardust3's Avatar
Default 07 Can am outlander ?'s
I'm a newbie here so please take it easy on me. Very nice site also, seems very informative. I've done some searching and having difficulty finding a solution for my problem.
I have a 07 500 H.O.can am outlander. I don't do much trail riding just use it mainly for work around our small farm. I am having issues with high temp light coming on and a lot of heat. Now these issues arise when I'm using a self powered pull behind DR Field & Brush mower(rough cut). I barely hit 5 mph and have atv under a load on somewhat hilly ground.
Is there anything I can do to make this machine run cooler so I can work it without having to stop all the time to let it cool down. I have cleaned the radiator & it is free of dust & dirt. As far as I can tell it seems to be intact, no warping of any kind. When high temp light does come on I immediately stop and let machine idle until it cools down then park it in the shade for a while.
I have read about engine ice for the radiator. Would this possibly help?
I am open to any & all advice. Thanks in advance.
Old Jul 27, 2010 | 08:59 PM
mudslinginfool's Avatar
Does it in the Mud!
ive got an 07 500 also and we found that the radiator was swollen shut on it. it had expanded so much that air flow could not get through even with the fan on. id take a look at it. If you can see through it,its fine. If you cant then id have it checked out. use a light if you need to.
Old Jul 27, 2010 | 10:13 PM
stardust3's Avatar
After closer inspection I see the fins in the middle of the radiator are swollen & have the vertical fins compressed.
I seen a picture of a new radiator on ebay and it did not look like the 1 in my machine. I'll be checking on a replacement tomorrow. Thanks for the response.
bigred20653
Oct 2, 2015 10:05 AM
panicmanic
Sep 28, 2015 12:59 PM
bigred20653
Sep 19, 2015 02:11 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Gtsordo
Jul 22, 2015 01:27 PM
