verry strange lt80 problem
Old Jul 28, 2010 | 02:51 AM
dodgefate's Avatar
Default verry strange lt80 problem
I have an 80s lt 80, had it since I was a kid. The thing always ran great.... untill my brothers kids got ahold of it! What I was told is that they were driving it, it started to bog dow and die. I looked at it and i noticed that when craniking it with the brake off the thing would roll forward. The only way to start it is to have someone push it and hold the started button at the same time. Feels like the clutch could be stuck? If you push it you can hear the engine turning over. Also it will bog down going up hills when it is running. If you give it gass with the brake on you can hear the drive belt squeel. ........ Just looking for some advice before i start ripping apart the wrong thing.... Any help would be greatley appricated.
Old Jul 28, 2010 | 08:11 AM
LT80's Avatar
LT80 Expert
I'd start in the clutchs since your not supposed to be able to turn the motor over by pushing it.
Old Jul 28, 2010 | 04:53 PM
dodgefate's Avatar
yea thats where i was going to start.... is that the cover that rusts up near th left foot peg?
Old Jul 28, 2010 | 11:24 PM
LT80's Avatar
LT80 Expert
The entire cover, not the little one.
Remove all 4 footpeg bolts and push them forward. They are a bugger.
Old Jul 30, 2010 | 04:29 PM
dodgefate's Avatar
ok i got it all ripped apart..... looks like about 4 dead mice in there locking the cluch together..... took em out and the rear is still hard to move.... also have verry weak spark, tried the finger trick and it barley bites me..... any ideas? I was thinking about ordering a new coil?
Old Jul 30, 2010 | 05:11 PM
dodgefate's Avatar
update..... Duh I forgot the brake was on so the rear is fine.... I had dull spark, stuck my finger in the carb and she started up. Then died right away... I have alternating 12 volt hot and ground on the one side of the coil and straight ground on the other side but no spark or shock now... I think its a bad coil just want to confirm
Old Jul 30, 2010 | 09:50 PM
LT80's Avatar
LT80 Expert
I'd do a compression test before I bought anything.
Old Jul 30, 2010 | 11:36 PM
dodgefate's Avatar
topend has lessthan 40 hours on it feels good also withought putiing a compression tester on it..... just no spark now
Big bousse
Sep 26, 2015 10:42 AM
ScopeZ_
Jul 28, 2015 01:44 AM
hondarider1234
Jul 21, 2015 11:53 PM
Unzzy66
Jul 11, 2015 10:01 PM
Wnthunting
Jul 9, 2015 03:02 PM
