1987 Big Bear stuck in 4th gear
Old Jul 30, 2010 | 03:50 PM
sweetmarie's Avatar
Question 1987 Big Bear stuck in 4th gear
Any advice for a 1987 Big Bear stuck in 4 th gear. Could it be something simple, adjustment, etc?
Thanks in advance.
SM
Old Aug 5, 2010 | 09:44 PM
sweetmarie's Avatar
1st, 2nd, 3rd, 4th 5th????????????
Old Aug 10, 2010 | 05:11 AM
sweetmarie's Avatar
Question
Here's a bit more info. High and low range works and so does reverse. Is this a bad time of year for asking questions or is it because there could too many causes?
Thanks again anyone.
SM
Old Aug 10, 2010 | 12:20 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default Big Bear
Does it have the semiautomatic transmission like the newer ones? I have an 08 big bear that has the semiauto tranny which has gears 1-5 and then you have to get in nuetral to go to reverse...mine has no high/low though. Is yours shaft drive or belt drive?
Mudslinger2
Old Aug 10, 2010 | 12:57 PM
sweetmarie's Avatar
Default 1987 Big Bear
Thanks for replying. It is shaft driven. You can go to reverse in any gear by pressing down on the rear brake pedal. As far as semi automatic or automatic, I would assume semi automatic as I have to shift every gear but no clutch lever.
Old Aug 10, 2010 | 01:52 PM
unit6666's Avatar
I would try to loosen up the clutch.. on the side of the motor you will see a nuts with a screw in the middle.. loosen up the lock nut and loosen up the screw in the middle.. it might allow you to shift again.. I dunno
Old Aug 10, 2010 | 06:19 PM
Default Trans
Before this started happening--when you shifted into reverse and then back out of reverse did it go back into the gear you were in or did it start back in first gear? I would agree with 6666...adjust the clutch tensioner and see what that does for you...seems to be a more complex than mine...I have no high/low...only five speeds rather than 10...you may look on partshark.com and see if you can find a free service manual for that model...wish I could give you more help I know it is frustrating to have stuff that doesn't work like it is supposed to...Good Luck.
Mudslinger2
Old Aug 11, 2010 | 05:17 AM
sweetmarie's Avatar
The atv in question is not mine, it belongs to a friend and I'm trying to help him. I also own the same atv, same year. Adjusting (loosening) the clutch sounds like a place to start, I know exactly where you mean. Thanks for your help. I will post back with results.
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Chuck188
Jul 17, 2015 02:45 PM
ghost civic
Jul 15, 2015 10:48 PM
sara durrant
Jul 6, 2015 05:32 PM
