Speed Limiter "spacer" on a XP 850?
Old Aug 2, 2010 | 08:47 PM
09' Sportsman XP 850's Avatar
Default Speed Limiter "spacer" on a XP 850?
I have heard there is some sort of "spacer" on the 850 Xp that can be removed to gain power?
Does anyone know if this is true? or how to remove the spacer? Or ever where it is located?
Old Aug 3, 2010 | 03:59 PM
bitterfitter's Avatar
I'm not sure for most 850 owners, but mine (sep 08 build date) will do 74 MPH... My friend Jeff's, a later build date, will do a little faster, but the last time we did a long WOT run, his belt came off. Just disintegrated inside the housing. So I'm not sure taking out a supposed speed limiting spacer is a great idea... besides, isn't 75ish fast enough on an 830lb quad?? (I know, it's never fast enough, the 850 is rock stable at that speed... it's so much fun)
Old Aug 3, 2010 | 06:37 PM
Mongrol's Avatar
"Official Site Skeptic"
Speed is fun, funerals aren't.
Old Aug 3, 2010 | 07:22 PM
You are so right Mongrel. But it's a risk one takes at times, when one is addicted to speed and power... I did not mention in my previous post that I havent had my 850 goin that fast since the belt issue on Big Jeff's. (My name is Jeff too, but I'm 90lbs lighter than Big Jeff, and 5 inches taller to boot). I do get to 60-65 during a some runs though, depending where we are riding. I like 69.1 HP and all it's virtues, and I respect how quickly things can get out of hand with 69.1 HP and 830 lbs.
Old Aug 3, 2010 | 09:47 PM
CaptainQuint's Avatar
They're probably thinking of a shock damper or spike damper. These are designed to slip and reduce shock load to the driveline. I'm guessing that if you remove it you can gain a little top end speed or something.
Old Aug 4, 2010 | 03:23 PM
The spike load damper is fixed until it is stressed to the slipping point, at which time it, well, slips a bit to take the stress off the drive train. On the AC's and Polaris's (the two brands I know of that have SLD's), once popped, the SLD will pop easier the next time. The fix is to replace or weld it tight. BTW, I havent popped mine, and neither has Big Jeff, and his 850 has 27" XTR's.
Old Aug 4, 2010 | 07:16 PM
WOLF1's Avatar
The spike or torque limiter is actually pretty easy to activate, if you jump the machine and land with throttle on it will activate. Or if climbing a slippery hill at WOT and you catch a dry spot with any one tire it will activate. Just my observation.
The speed limiting spacer that was referred to is a shim in the clutch. It prevents the clutch from traveling all the way and thus limits the final drive ratio.
Old Aug 4, 2010 | 11:10 PM
Mongrol's Avatar
Will the SLD activate with ADC on and going downhill slowly? Feels a bit like jumping out of gear.
Pehter
Oct 3, 2024 11:00 PM
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
ReconBayou
Sep 23, 2015 02:41 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
