electronic issue 4wd tripping beaker help needed
Old Aug 4, 2010 | 08:20 PM
randyneff6971's Avatar
Default electronic issue 4wd tripping beaker help needed
I have a 90 trail boss 4wd. All the electronics on the quad seems to be working fine, however when I flip the 4wd switch the indicator light comes on for about 2 seconds then I hear the inline 10amp circuit beaker tripping. If i leave the switch alone I can hear the beaker reset and it trips off again at the same time the 4wd is not engaging. I did notice the reverse over-ride switch looks like its pressed in (stuck in) . I`m leaning towards a dead short somewhere and I will find it but thought someone here, may have had the same problem and could save me some time as to where to look.
Thanks.
Old Aug 5, 2010 | 08:25 PM
Anyone ever have this problem? what did you do to fix it?
Old Aug 5, 2010 | 08:53 PM
Jaster94's Avatar
I sent you a PM. check it. still working on this for ya. bear with me.
Old Aug 6, 2010 | 05:34 PM
Got your PM thanks, message sent back.
Old Aug 6, 2010 | 08:00 PM
THREAD UPDATE: Short has been narrowed down to the right front wheel. When I unplug the power supply wire to the engagement coil the other wheel stays locked and the circuit beaker dont trip. I`ll figure out what the problem is tomorrow and post it here. Thanks for all the help Jaster94.
Old Aug 7, 2010 | 04:18 PM
Turns out that the magnetic coil in the right front wheel is toast, I was hoping it was a broken wire. looks like i`m off to get raped at the steelership.
Old Aug 8, 2010 | 03:35 AM
MrMarty51's Avatar
Maby post in the classifieds"part needed".
SOLOLUCKY
Oct 4, 2024 09:09 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
cowboy
Feb 29, 2000 09:16 PM
