DEAD 2007 Polaris Sportsman 500 EFI Deluxe
Old Aug 5, 2010 | 11:35 AM
oil.country's Avatar
Exclamation DEAD 2007 Polaris Sportsman 500 EFI Deluxe
Good Morning,
I am struggling to find the answers for why my quad is essentially NFG.
The back story is this:
Went out for a weekend ride, everything ran fine. Loaded the unit on the trailer and headed out to work, where I use to ATV as well.
Got to work destination, 5+ days later tried to start ATV. It started, ran for a few seconds then died. I tried it a few times, each time it would stall.
1) My first guess was the battery. Purchased a new battery, trickle-charged it - no go. However, after this the speedo would illuminate but it would just flicker and quit. Fuel system charging sound was reduced to a low hum and the clicking sound when key is turned off was not present at all. But, I still had some hope that power was getting at least to the speedo.
2) After battery was found to be good I bought a new solonoid and replaced it. Nothing. I jumped the solonoid and can get the quad to crank but will not fire. I can hear a popping sound, like it is shorting out somewhere in the forward of the engine.
3) Called Polaris service tech - maybe ECM is screwed. I have 2 of the same ATV. Took ECM from bad quad and put it into the "good" one - fired up. Took ECM from good quad and put it into the bad one - nothing.
...now I'm frustrated...quad torn apart....wow.
4) Called Polaris service tech - ahhh, fuses..? Told me to check by the rad, nothing. Called again. Check by the steering column. Something about a fusible link in a plastic pouch on the side of a wiring harness?
Does anyone know anything about the pouch or the fuses and if this could be something related to the problems I've been having?
I would be very appreciative of anyones help. I'm stuck.
I have a feeling the service tech is getting sick of hearing from me or he thinks I'm crazy. Being a girl, I guess I'm hard to take seriously! LOL....!
Any comments are appreciated.
Old Aug 5, 2010 | 11:53 AM
TLC's Avatar
TLC
Check all connections that may be dirty or loose and look for any shorts bare wires..
Old Aug 5, 2010 | 06:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
didnt you say it's clicking? if so then power (some) is getting through so it should be a fuse issue. sounds like you might be right about a short or dead ground out some where.
Old Aug 5, 2010 | 07:10 PM
racer37l's Avatar
Listen to the relays. Sounds like a coil going bad.
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
