Primary clutch squeak after installing clutch kit
installed an EPI clutch kit and now my primary clutch is squeaking. I removed the belt and it went away when I reinstall the belt its still fine until the first time I enagage the belt then it squeaks again
Thanks for help
Its a Sportsman 700 EFI 2005
Heres a video of it
http://www.youtube.com/watch?v=npReJKRUt0A
Thanks for help
Heres a video of it
Thanks again
if you can bring down the belt a little(by doing as you mentioned) then i would say it would be fine. it wouldn't hrut to try as it sounds as it's a hair too tight causing the squeel which could start to creep ahead some. imo
Did you measure your belt deflection should be 1 1/8 - 1 1/4, looks to me that the belt is to tight from watching video.But you have to add shims to to open up driven if you take out shims it'll make condition worse.
Thanks
I had 3 washers in the few I've seen, I'm down to one on mine they come in different thickness too. Did you put on a new or different belt that could be the reason for tighter belt. Also hows your belt to sheave clearance on driven should be .020 if thats to tight that could cause your problems too.
OK I'm leaning toward it being a clutch alignment issue now also. If itake the belt off theres no issue at all so it cant be an issue with the primary
. Belt looks like its in the middle but I think I may have to add another shim there are 2 now. If I put alittle presurre on the belt outward the noise goes away.
Could it just need a new belt ? Or should I add another shim
Can I just use an Regualr washer ? Or do I need the polaris ones not sure if theres a difference
Thanks again in advance for helping
cdstang
Aug 31, 2015 07:52 AM
