electric prob
Old Aug 10, 2010 | 07:56 PM
itstillruns's Avatar
Default electric prob
I replaced stock headlights with aftermarket. Now quad will run short time and stall/shut down. after unplugging lights it runs fine .But with high beam (no low beam and 4x4 coil on it shuts down . what and where relay did I kill?
Old Aug 11, 2010 | 03:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like it's drawing way to much current. is it installed correctly w/ the right relay's?
Old Aug 11, 2010 | 08:19 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Is it a newer Quad with the ECM (Sure Power Module)??
You did not list a year or model.
....Caper.......
Old Aug 11, 2010 | 08:21 PM
My 2006 Sp 450 would shut down when the lights were turned on (stock ones) this was the solid state circuit breakers shutting the Quad down for protection.....when I turned the light switch off and cycle the key back to off ....It would start again...............Until the light Switch was put on again...........Caper............
Old Aug 17, 2010 | 11:00 PM
all i did was replace stock headlights with after market " driving lights" 55w walmart specials
Old Aug 18, 2010 | 06:38 AM
all this sounds like my problem but where is the relay or breaker I tripped located so I can test it? I simply cut the stock headlight wires and added push connectors with new headlights. let the quad sit it resets its self and runs fine until I turn anything electric on. Then it shuts down.
Old Aug 18, 2010 | 07:24 AM
There is no relay or breakers if you have the Sure Power Module (black box),,(Silver is the new replacement one) the have solid state circuit breakers installed directly into the module.........The quad shut down on me right away when the lights were turned on.........If the Recall was not done =check into it.
The reason the Quad turns off is for protection.........Caper..........
Nobody listed a year or model quad yet? Mine was on two Sp 450's ..2006 year.
Caper..........
Old Aug 18, 2010 | 08:24 AM
MrMarty51's Avatar
Caper..........
If You still have the old style module and the dealer is doing the recall replacement,be there when the mechanic is ready to install the new module,have Him remove the cover and make sure it is not filled with corossion,please do`nt ask Me how I know lest it start another rant.
Old Aug 18, 2010 | 11:14 AM
TLC's Avatar
TLC
I know ,it should be the first thing before a question. Thats why you put your ATV in your signature then you can skip that part.
I tried these super duper brigh blue light bulbs in my sled last winter,they blew my Voltage rectifier and melted some wires. Big mistake.
His sounds differen though,he stayed with the same 55W rating as stock and just did a straight foward wire connect. Should of worked simple.
Old Aug 18, 2010 | 11:45 AM
Default year
Oh I suppose this would help! its a 04 700 SP, early 04 carb model. still runnin! sorta
