electric prob
Old Aug 18, 2010 | 12:10 PM
TLC's Avatar
TLC
Well I don,t see it on the ECM recall list Polaris Industries Expands Recall of ATVs Due to Fire Hazard
Old Aug 18, 2010 | 04:48 PM
Overdrive's Avatar
On your machine you can not run two 55 watt lights directly off your stock switch and circuit.
On the older machines with the stater button built in to the light switch you could. On a Polaris that starts off the key switch it WILL fry your light, high-low, and override combo switch.
You must run it through a relay on the newer machines. Your charging system will pull the lights OK as long as you don't sit and idle for longer periods.
Old Aug 19, 2010 | 08:27 AM
itstillruns's Avatar
Unhappy electric prob update
well its a early 04 700. all ignition stuff is black the manufacture name is some japanese co. kabu...or something like that any help?
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
