CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Help!! Can't Seem to Seal Chain Adjustment Plug
Old Aug 13, 2010 | 03:22 PM
slipfit's Avatar
Default Help!! Can't Seem to Seal Chain Adjustment Plug
After adjusting the valves on my '07 DS650 it starts much better. Unfortunately, Now I can't seem to get the tensioner plug to seal. The o-ring wants to pop up and over the head of the plug when turning it tight. Tried puting in finger tight...leaks. Tried somewhat tight...leaks. Tried putting the o-ring in the casting...could not start the plug threads.
Is this a common problem, or am I being affected by Friday the 13th??
Any and all reasonable suggestions will be tried and reported on.
Thanks in advance.
Old Aug 13, 2010 | 03:27 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
What did you lube the o-ring with? Some lubricants make o-rings expand, or seem to stretch. Wipe it dry, set it in the fridge or freezer for a few minutes, give her another shot. Super O-Ring Lube works best and prevents the "stretching" effect.
Old Aug 13, 2010 | 03:41 PM
slipfit's Avatar
Thanks for the quick reply aceisback.
It just had residue crank case oil on it. I like the frige or freezer sugestion, it's about 90 degrees F in the shop right now... trying it now.
Old Aug 13, 2010 | 04:23 PM
slipfit's Avatar
Fixed!!
I was being affected by the 13th. I didn't take it apart, a friend did. When I put it all back togather I put the plug from the crank case cover on the right side into the tensioner plug hole and the tensioner plug into the cc cover. Threads fit nicely. ooops. Switch them back around and presto....no more oil leak.
Wow, sometimes I surprize myself at my ability to turn a hour job into hours of frustration!!
Old Aug 13, 2010 | 04:47 PM
aceisback's Avatar
Military Rider
Glad you got her figured out.
Old Aug 14, 2010 | 05:30 PM
dathompson's Avatar
Default lol
glad you got it figured out too, man that kinda stuff happens to me, but a lot more when other helping hands are at the bench lol.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
chammerbeck
Jul 17, 2015 08:06 AM
Coryco
Jul 6, 2015 07:30 PM
