my polaris doesnt do anything when turn the key
Old Aug 16, 2010 | 12:27 PM
coottermac's Avatar
Unhappy my polaris doesnt do anything when turn the key
It is a polaris sportsman 500 2007 does nothiong when i turn the key not even the electronis turn on ive checkd the battery and tryed to find the fuses but im having no luck if anyone knows what might be wrong please hep me
Old Aug 16, 2010 | 12:59 PM
JK500sp's Avatar
it has to be a fuse did you check under the high beam headlight there is a front cover there and in the front storage compartment. Mine has a rubber cover inside the compartment to lift and see the fuses
Old Aug 16, 2010 | 01:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. if your battery is 100% good and charged and your sure the kill switch isn't on then most likely it will be a fuseable link in the battery (red) cable some wheree along the line. it might be covered by a black rubber pouch.
Old Aug 17, 2010 | 07:43 PM
racer37l's Avatar
If your bike is like mine(07 sporstman 800), the fuses are inside the front storage box. Open the box and look in the middle of the box toward the headlight pod, there should be a rubber cover that may have spare fuses in it. Remove this cover by pulling up on it, the fuses should be visible along with the radiator cap.(It will be one of the 20A fuses) Good luck
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
txkevin
Sep 21, 2015 02:02 PM
tweeder
Jul 5, 2015 01:57 PM
Shifts
Jul 3, 2015 07:59 AM
