CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
coolant in oil, whats wrong?
Old Sep 4, 2010 | 04:47 PM
ds650 baja's Avatar
Default coolant in oil, whats wrong?
I am new to the DS650 family and now I have Coolant in my oil, and i'm trying to determine if i have bad seals in my water pump or bad head gasket. Is there a way to rule out either the head gasket or water pump without major de-construction. Im not burning the coolant, its just going into the oil. Any constructive feedback is appreciated.
Thanks!
Old Sep 4, 2010 | 07:28 PM
dirtjunkie's Avatar
leaking water pump seals are pretty common on the DS650, I had the same problem when i owned mine, since its not burning any coolant or misfiring from burning coolant i would suggest that you water pump seals have went south
Old Sep 4, 2010 | 09:13 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
under your water pump there is a weep hole make sure it is open and if it is the water pump it should drip on the floor
Old Sep 5, 2010 | 07:15 AM
ds650 baja's Avatar
ok thanks, i will check the weep hole, if it is plugged do i have to remove the cover to unplug it? what is the easiest way to unplug it?
Alex G.
Sep 11, 2017 11:38 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
