coolant in oil, whats wrong?
I am new to the DS650 family and now I have Coolant in my oil, and i'm trying to determine if i have bad seals in my water pump or bad head gasket. Is there a way to rule out either the head gasket or water pump without major de-construction. Im not burning the coolant, its just going into the oil. Any constructive feedback is appreciated.
Thanks!
Thanks!
leaking water pump seals are pretty common on the DS650, I had the same problem when i owned mine, since its not burning any coolant or misfiring from burning coolant i would suggest that you water pump seals have went south
jrooker6
Apr 23, 2016 07:36 PM
