small leak around front diff 2007 800 sportsman
Any of you experenced this leak issue. If i were to guess it looks like it is right where the axel enters the diff. on the right side. Is there a seal right there that could need replaced? Any help would be appreciated...and thank you!
Gat
Gat
Yes it is the seal, it is a very slow leak, and it is a normal problem from what i understand from my service department. They suggested I do it myself by putting differential sealant in it, running it awhile and emptying it out and refilling with the proper fluid. That has seemed to work on mine.
I also hear it is a problem if you overfill. It appears these fronts take just the amount listed, no more.
Rooky
10
Jun 23, 2015 09:35 PM
500, 800, atv, axle, diff, differental, differential, front, leak, leaked, leaking, overfilled, polaris, sportsman, touring
