99 Grizzly fan not running
Old Sep 17, 2010 | 03:43 PM
hound dog's Avatar
Default 99 Grizzly fan not running
HI 99 Grizzly oil cooler fan not comming on oil temp light comming on is there a seaprate fuse for this what controlls it how do i check it
Old Sep 17, 2010 | 05:25 PM
TLC's Avatar
TLC
Check the fan, jump a direct 12v source to the fans two leads and see if its spins. Is the oil temp light constantly on?
Old Sep 17, 2010 | 07:28 PM
Mud Slinger's Avatar
There should be a sensor in the radiator that tells the fan to come on when the coolant hits a certain temperature. It should have an electric clip on the sensor with two wires going into it. Take the clip on electric fitting off the back the sensor. Start your grizzly and use a small bit of wire and jump the two metal tips in the wire clip. That should cause your fan to start running. If it does, you need to replace the sensor in the radiator. Costs about 30 bucks and takes 15 minutes if that.
Old Sep 21, 2010 | 07:02 AM
hound dog's Avatar
no oil temp light not on all the time oil cooler rad is clean will try to jump to jump the fan this weekend thank you all hounddog
RticKwad
12
Jul 19, 2015 12:22 AM
TLC
Jul 1, 2015 08:29 AM
RPK
Jun 8, 2015 01:05 AM
atvdave
Jun 4, 2015 06:06 PM
Undecided350
Jan 15, 2001 03:55 AM
