00 sportsman 500-carburetor help
Old Sep 20, 2010 | 09:51 PM
kevinde1's Avatar
Question 00 sportsman 500-carburetor help
Hi I have a 00 sportsman 500 recently i noticed that it wouldn't rev like it was supposed to so I decided to clean my carb, change the plug and set the valves. After I got it running again the problem was worse than before so I took off my air-box to see what was going on and I noticed that the throttle valve/ diaphragm is not opening all the way. I inspected the diaphragm real good and it seemed to be in good shape. I was wondering is there possibly another reason this thing isnt opening? If I use a screwdriver to lift it while throttling, it revs great. Also if I replace the diaphragm should I replace the Jet block assembly too? Thanks for your replies.
Old Sep 29, 2010 | 05:06 PM
kevinde1's Avatar
Well didnt get any reply's so bought the throttle valve/ diaphragm and jet block and i noticed that the new diaphragm didnt spin around on my throttle valve like it did on my old one. So if anyone is having problems with your bike not reving up like its supposed to, pull the air box and check your throttle valve and see if its opening. If not you may have a bad diaphragm.
Old Sep 29, 2010 | 06:04 PM
Overdrive's Avatar
It will not open with the air box off.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
