Which oil for a LT80?
Old Sep 21, 2010 | 02:47 PM
Reyn's Avatar
Default Which oil for a LT80?
What kind of oil is it that i need to fill the reservoir? Can i get it at Lowes?
Also, i don't know what the original owner used and the tank is a little above minimum level mark so i am gonna fill it some more.
Since i don't know what kind is in it (synthetic,regular?) i shouldn't mix, right?
Old Sep 21, 2010 | 03:03 PM
TLC's Avatar
TLC
You can mix synthetic with conventional Mixing Petroleum and Synthetic Two-Stroke Oil - ThumperTalk I have to do it all the time on my sled when I,m far out and the hick store only sells conventional 2 stroke oil.
Old Sep 21, 2010 | 03:12 PM
Reyn's Avatar
Thanks.
Can someone tell me if it is normal to have little puffs of white smoke even after the quad has been riddin a while. It's fairly smokey upon crank up but fades down to little puffs after a few minutes. It isn't gonna disappear completely after warm up is it?
Sorry for the newb questions. I know it can be repetitive for older members. I am also using the search in between.
Old Sep 21, 2010 | 03:21 PM
TLC's Avatar
TLC
2 strokes smoke betty good from cold starts but improve as they warm up but there will always be more smoke than a 4 stroke. Yours sounds fine.
Old Sep 22, 2010 | 02:11 PM
DSengineer's Avatar
Has been here a long time!
I run Redline, buy it by the gallon. Lots of smoke at stratup until its good and warm.
Old Oct 18, 2010 | 01:56 AM
aaronrkelly's Avatar
Reyn,
If your still here I would like to clarify that you know the function of the oil in a 2 stroke motor. Im not intending for this to sound demeaning so dont take it that way......just in this day and age with 2 strokes on their way out I think some people dont understand the difference.
The LT80 is a 2 stroke motor - that means the oil is injected with the fuel and burnt inside the cylinder. Its job is still to lubricate but its different then a 4 stroke because it gets consumed. You dont change the oil on a 2 stroke....you burn it.
Keep an eye on that level......if you run out you will burn that motor up in short order. You need to keep it topped off.
As far as what.....any 2 stroke oil beats nothing. Past that its personal preference. I run Belray.....but any good 2 stroke oil will be fine. I would personally suggest sticking to a 2 stroke MC/ATV oil and NOT using a Marine based 2 stroke oil.
Old Nov 2, 2010 | 11:22 AM
mike75925's Avatar
i buy the gallon @ walmart. suitable for marine, premix, and all injection pumps. i think it is around $11. what have i ran it in? '72 -'74 gt750's, rm125, polaris atvs, my lt80, my ody, and pretty much every two stroke i work on. no failures. when you first crank a 2 stroke, the reason they smoke more is that the gasoline has vapored off leaving the oil behind. this occurs in a greater capacity the longer the engine sits between uses. this is a good thing as it preserves your bearings, seals and rings. if just gas was in your crankcase, your seals and the rest would fail sooner. if your 2 stroke has a tranny, you still have conventional motor oil in it. granted, you do not have to change it near as often, you should still keep an eye on it. hope it helps.
Old Mar 11, 2011 | 07:45 PM
J-Mitchell's Avatar
Belray will clog the injector pump
Old Mar 16, 2011 | 03:54 PM
DSengineer's Avatar
The heavy smoke on mine was the result of the injector. Since recently going to 32:1 premix it is night/day difference.
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
