Transmision Fill Plug 07 800 X2
Old Sep 21, 2010 | 07:22 PM
jampg's Avatar
Default Transmision Fill Plug 07 800 X2
I can't get the flippin trans fill plug out. Of course the drain plug comes right out. Rapped on it a couple times, penetrating fluid, WD-40 and some heat for a last effort. No luck. It won't be long before I strip the head. I through in the towel and gave it another soaking of WD. What else?
Old Sep 21, 2010 | 08:17 PM
I've had the same problem on a couple fill plugs, ended up using my snap-on stripped screw/bolt tools to remove the plug using a cheater bar and replacing with a new plug! Drain plugs are never a problem! Can't explain,but I had already changed the fluid on one previously and didn't over tighten! They seem to tighten and freeze up on their own at times.Might have to do something with them actually being a hollow plug and expanding?? OPT
Old Sep 21, 2010 | 09:27 PM
randyneff6971's Avatar
just drain it, flip the bike over and refill through the same hole.
Old Sep 22, 2010 | 06:39 AM
UTU's Avatar
UTU
I tried flippen mine over works great cept for broken collar bone and left side ribs got broke (:<
Old Sep 22, 2010 | 06:51 PM
MECHANIKE's Avatar
Your not flippin supposed to be sitting on the beast going 47mph heading downhill in a hurry!!!!
Old Sep 22, 2010 | 07:03 PM
jampg's Avatar
Default good and bad
Got the fill plug out today with a pneumatic impact wrench. Should have used that in the first place. I did manage to snap a wheel stud while removing the tire. Go figure.
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
rcappie4
Jul 10, 2015 04:54 PM
