06 sportsman 800 EFI will not stay running
Old Oct 5, 2010 | 08:12 PM
KC7JLM's Avatar
Default 06 sportsman 800 EFI will not stay running
I have a 06 sportsman 800 EFI that will turn over but not start. If I spray gas in into the intake it will start and run until it uses the gas sprayed. Is the EFI module bad or a fuse???
Thanks for the help
Old Oct 5, 2010 | 08:48 PM
On the fuel rail end hold the small plunger in,should get a little air and gas,then while holding pin in,turn key on (don't try to start) if no gas flows out,then possible fuel pump out. Should be able to hear pump prime if good. Pumps are available now through Polaris without having to buy tank assy or can get even cheaper through Napa,etc. Other members can give you the best prices,if its the pump. OPT
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
skittero
35
Mar 1, 2019 12:39 AM
kbbgood
Utility ATVs
24
Mar 9, 2016 03:08 PM
jayking232003
Jun 9, 2015 02:54 PM
