88 TRX300 No spark
Old Oct 10, 2010 | 06:20 PM
hunter99's Avatar
Default 88 TRX300 No spark
I have wrung out all wires from front to back and have continuity on all.Have performed all resistance tests and all check good. Have swapped the CDI and alarm with known good units. Swapped alt/rect with known good unit and still no spark.Any help would be appreciated. I have searched this site for the last 3 hours for reference. Thanks in advance.
Old Oct 10, 2010 | 09:09 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Have you checked the lenier diode in frt of tank inside the junction box black wires have two spades!
Old Oct 11, 2010 | 07:58 AM
EPI Brandon's Avatar
check the pickup coil i beleive the resistance check is 470 to 580ohms. also move the kill switch back and forth well checking spark.
Old Oct 11, 2010 | 09:22 AM
hunter99's Avatar
Pappa,checked the diode and it was good.Epi,coil checked good. I'm not getting any voltage to the power side of the coil.I have checked every groung three times.Have power to the CDI.On-Off switch works good.
Old Oct 13, 2010 | 06:55 PM
Loved
Community Favorite
Well if you have power or signal to the cdi and not getting power or signal off of cdi to the coil than cdi or harness or spade or connector. did you do test on wire ends [connuity]from cdi to coil to see if wire is broke?PS Was the known good cdi the same year? the 1988 got to be only 1988 cdi if oem one.
Old Oct 13, 2010 | 09:30 PM
hunter99's Avatar
Pappa,went back over the whole harness again for the third time.Continuity throughout,all good.Went back over all of the Ohm requirements for each component,all good. I remembered seeing a post on beating the crap out of the CDI,so I picked one-beat the crap out of it,plugged it in and it has a bright blue spark.Plugged in my other known good one(I thought) it didn't spark. So after pulling my hair out and diligently going through the whole harness 4 times (I am a 30 year airframe and powerplant mechanic and pilot) the Large hammer won me over.New CDI ordered and on the way. Thank you for the interest this is a great forum and has helped me several times.
Matt
Old Oct 15, 2010 | 12:07 PM
Loved
Community Favorite
Matt keep us updated Bro.
Old Oct 15, 2010 | 04:18 PM
hunter99's Avatar
Will do Papa,Love them engines too!New CDI on the way.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
