450 kodiak
Old Oct 14, 2010 | 11:29 PM
coolnighttrain's Avatar
Cool 450 kodiak
Can someone please help me. On the front u-joint greaser it is tight. I have tried to use a grease needle but still can't get grease in. Is there another way ? Plus one more thing when I put it in park the light won't come on unless I wiggle the shifter or the atv forward and back were is the sending unit?
THANKS
Old Oct 18, 2010 | 08:02 AM
CraZySteve's Avatar
Welcome to the Forum!
For the front u-joint you need a 90-degree grease tip. They cost like $10 but well worth it!!
In regards to the park light. The sending unit is just above where the shift rod enters the engine/transmission. I have to rock mine to get it into park and even rock it to get it into Low gear. The rod is pretty easy to adjust I have mine adjusted to where I am used to using it. Do a search on the forum and you will fine the Shifting issue addressed.
ALSO -- I do have the service manual for 03-06 Kodiak 450's so if you want a copy PM me your email address.
-CS-
Old Oct 18, 2010 | 11:57 PM
Default tight spot
-CS-
Thanks for the reply I do have a manual. But to re&re the tipple you can't get a small socket in. Do I need to drop the drive shaft?
Thanks Terry coolnighttrain
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
