'06 350 Rancher 4trax won't start
Old Oct 18, 2010 | 04:04 PM
shankmeister's Avatar
Default '06 350 Rancher 4trax won't start
HELP!!
My son was riding it in the woods, got it hung on alog, shut it off, took the key out, we pulled it off the log, now it won't start. Never had any troble with it before. Easy start and runs strong.
Where do I begin?
I understand basic mechanics and the whole fuel, air, spark thing, but these things are foreign to me. I got the side skins off and can't find anything obvious. Found what I believe to be the electronics under the right rear fender. Can't find any damages to anything any where.
Oh, yeah, I have a skid plate under it for a plow attachment. That is what was on the log. And by the way, the log was mostly rotten.
Any advice would be appreciated with pointers on where to find the check points. I need to mow and don't have time to run down the maintenance manual.
Thanks folks!
Oh yeah, one more thing, it cranks, just won't fire and doesn't even try (no spit or sputter).
Old Oct 18, 2010 | 04:41 PM
Doctorturbo's Avatar
GOT BOOST!
Here is where I would start:
#1 Check the tank for fuel........as silly as it sounds........
#2 Make sure the fuel switch is on. (if it has one)
#3 Pull the plug and ground it and see if you get spark.
Start out with these and see what you get.
Old Oct 19, 2010 | 02:03 PM
Thanks Dr turbo.
I hope to get some quality time in the garage to check the basics tonight. Are these things fuel injected? I read some comments about some models being injected?????
I did check the fuel, there is plenty in the tank. Moved the shut off valve through all positions.
L8R
Old Oct 19, 2010 | 08:54 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Also I would check the left handlebar kill switch make sure in twisting and turning the handlebar trying to push that the switch didn,t get pushed to stop. should be in the center of marking. Just an guess first.Also if it was off while you have been trying to crank it you have an fouled plug now.Good Luck Please get back with us.
Old Oct 20, 2010 | 04:08 PM
WOW....what a newbie....neophite......rookie.....roodiot! (rookie idiot)
I never use the kill switch, not even sure why it was put there with a key ignition. My son or I must have bumped it to off. That was the problem all along.
Poppa Hogg, you are the man!
I work in computers and have done phone support and we ALWAYS start with the basics....is it plugged in, did you turn it on....
I feel like SUCH an idiot. I would have had this thing apart on the floor trying to figure out why it wouldn't kick over before I would have thought to look at the kill switch!
Many ,many thanks!
Old Oct 20, 2010 | 09:59 PM
Loved
Community Favorite
Glad you got it going man... and yes you are welcome.... Just an lucky guess...Ride Safe.
neilbedwell
Nov 10, 2018 11:02 AM
Marc Parish
Jun 26, 2015 09:37 AM
ROWALKER
Jun 15, 2015 05:38 PM
RedRancher
Jun 4, 2015 12:29 PM
1000gade
May 27, 2015 12:37 PM
