99 sportsman 500
Old Oct 20, 2010 | 10:28 PM
Blackhills's Avatar
Default 99 sportsman 500
When I'm in awd and going forward I will stop and go into reverse pushing override button it wants to pull real bad like one hub is locked in and one isnt, anyone have this problem
Old Oct 21, 2010 | 07:16 AM
Kerbbirds's Avatar
Change the oil in the hubs
Old Oct 21, 2010 | 09:20 AM
EPIChad's Avatar
You need to clean the hub and bearings and put new oil in it. The Polaris oil is best.
Mine would do that because I had a bad hub seal. Sometimes when it would start to do it you would need to go forward and backwards a few times to make both sides work the same.
Old Oct 21, 2010 | 09:31 AM
TLC's Avatar
TLC
More than you care to know about Polaris AWD hub link. ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
If your seal is gone it will leak at the inside of the wheel rim. just changing the fluid and taking nothing apart will fix that problem in most cases.
Old Oct 22, 2010 | 08:31 AM
EPI Brandon's Avatar
Make sure when you disasemmbly the hubs you clean up the armature plate that gets magnatized thats usually the main thing that starts hanging up. its just the small thin black plate i usally use really fine sandpaper to get out any grooves it may have caused.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
