1987 yamaha warrior 350 wont start
Old Oct 22, 2010 | 07:19 PM
gatoreng1's Avatar
Unhappy 1987 yamaha warrior 350 wont start
Just replaced the stator,swapped coil for one which has been tested. replaced cdi box for another used one,,,,,turn the ignition switch, push the start button, and the bike turns over, but does not fire until the start button is released.... and then only for a second... anyone have any ideas?
cbaker
Old Oct 22, 2010 | 08:02 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Sounds like need new cdi! ground is bad inside cdi.IMO! Did all cdi do the same thing?
Old Oct 23, 2010 | 09:37 AM
gatoreng1's Avatar
Thanks for the quick response.....I got the bike used, and don't know that the cdi unit was bad...It did have a starter clutch that needed replaced, as such, I hadnt seen the bike run. The bike did the same thing with the original CDI unit. It is possible they are both bad, but hoping for some other ideas....
Old Oct 23, 2010 | 02:31 PM
trialsrider172's Avatar
How old is the battery?
Old Oct 23, 2010 | 06:33 PM
gatoreng1's Avatar
I dont know how old the battery is,,,but it does turn over nicely....could it affect the fire?
Old Oct 23, 2010 | 08:05 PM
have you checked the spark?
Old Oct 24, 2010 | 08:07 AM
gatoreng1's Avatar
The bike fires when the start button is released. Checked also with plug out of bike.
Old Oct 24, 2010 | 10:59 AM
i bet its a bad battery. my friend did all kinds of electrical diagnostics on his warrior to find out that it was a bad battery. When batteries get tired they cant make a spark under the load of turning over the starter so when you let off and the starter is winding down and not under a load, sometimes it can make a spark. try a different battery if you can, or have yours tested
Old Oct 24, 2010 | 01:30 PM
gatoreng1's Avatar
Good point, but I found out the battery had recently been replaced. But I have heard that a bad starter can drain the power from spark...
Old Oct 24, 2010 | 08:12 PM
Loved
Community Favorite
Hmmmmm. never heard that!!! I know honda had an issue with 95 and 96 trx 300 with bad cdi,s They had them made by another distuber and the ground was made incorrect and the atv,s in the years i mention would fire after starter button was repleased we did reground neut.switch and this help BUT then honda decided that the cdi was wrong after we did warranty on the neut.switch reground and they did research and foundt out that cdi was the problem and recalled them models.You may have an ground in harness thats bad! I guess i would make an temporay ground to harness to batt ground, then if don,t help ground engine to frame.... Let,s see whats happens... Get back with us...
njrider64
Jul 4, 2017 01:40 AM
mikey426
Jun 17, 2015 03:53 PM
dano00
Oct 7, 2000 08:13 PM
PuhiStrain
Sep 9, 2000 01:36 PM
dunc_n
Aug 26, 1999 09:32 PM
