850 XP Shock Adjustment
Old Oct 25, 2010 | 09:11 PM
09' Sportsman XP 850's Avatar
Default 850 XP Shock Adjustment
Im just trying to figure out how to stiffen my front suspension using the spring tool, is the highest groove the stiffest setting?
Old Oct 26, 2010 | 01:05 AM
MudAddict's Avatar
Yes the highest setting is the stiffest.
Jacking the quad in the air with tires of the ground.
Will relieve some tension from the spring. Making it easier
To turn with the spanner wrench. Some wd40 maybe needed to help with the job.
Old Oct 26, 2010 | 08:59 AM
DingoNutz's Avatar
Does adjusting the spring tension adjust ground clearance of the quad as well or simply spring pre-load?
Old Oct 26, 2010 | 10:00 AM
Speeddrive1's Avatar
If your springs are sagged out then it should lift the front end some.
Old Oct 26, 2010 | 10:16 AM
PCL's Avatar
PCL
technically the lowest groove is the stiffest and you gain maybe a half an inch in ground clearance.
Old Oct 28, 2010 | 10:44 AM
So is it the lowest groove OR the highest grove to obtain the stiffest shock setting? I put a Moose Plow on and Im looking to eliminate some of the front end sag...
*Lowest grove being the 1st notch. Highest grove being the last notch*
Old Oct 28, 2010 | 04:45 PM
Boss Man's Avatar
Take a minute to look at it, and you'll be able to figure it out. The more "compressed" the spring is, the "stiffer" the setting. When it is in the "lowest" notch, it is compressing the the spring the most... stiffest setting. Each notch "up" drops the adjuster and "decompresses" the spring a little at each notch... softer setting.
Old Nov 11, 2010 | 12:03 AM
biz4two's Avatar
Thumbs up
Hope this pic helps...
biz
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
