No headlights on my 96 xplorer!...Whats wrong???
check for power going out to them w/ a tester to see if the bulbs are blown. if no power at the connections to the bulbs then check the switch it self to see if there is power there. if you do find power at the wires whee it does hook to the light bulbs and see they are burned out, check the voltage before putting new bulbs in to make sure it's not over charging that it will blow the bulbs again. if overcharging is happening then regulator is bad.
