how long does the front hub seal last???
Old Mar 7, 2001 | 08:46 AM
Harold's Avatar
my right front lasted only 45hrs, it's the factory seal. i just thought it would last longer, also the rear brakes were wornout at 32 hrs. i know, if you play in the mud you'll pay in $$$$$$$.
Old Mar 7, 2001 | 10:34 AM
MNXPLORER's Avatar
Harold, it is usually just a peice of grass or other debris jambed up into the seal. If you catch it right away you can often get away with dis-assembling, cleaning and re-assembling the hub. If not the seal is under $10 bucks. Don't let your dealer scare you hub dis-assembly and re-assembly is not difficult. Just make sure you lay out the parts in the order they come out. Also watch the bearings they like to head for the floor when you pull the hub off.
Old Mar 7, 2001 | 12:27 PM
Harold's Avatar
thanks for thr bearing tip!!
Old Mar 8, 2001 | 02:06 PM
RollOver's Avatar
on my 00 scrambler 500 4x4, i just finished replacing both my front hub seals. I think maintenence is everything on these (especially) machines..
Old Mar 8, 2001 | 02:23 PM
ChopperBill's Avatar
If the wear sleeve has a groove in it you had better replace it or you will be doing it over again soon. Thats another $24. Tried to get by on my old 500 Xplorer and had to do it again in about 100 miles.
Old Mar 10, 2001 | 06:10 PM
seacow's Avatar
One other thing you can do, press the seal in about .0020 further than the stock. This will let you start a new grove and get more hours before replacing. The whole operation can be done in less than 20 minutes.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
