05 sportsman wont start
Old Nov 1, 2010 | 06:56 AM
armyrepsol's Avatar
Default 05 sportsman wont start
Hi I'm new to this forum, I have a 05 sportsman that wont start, when I turn the key on i have full power to the lights and winch. When i go to turn it over all i'm getting is a clicking noise coming from what i think it is the starter relay, can some one please help me out on this one.
Thanks armyrepsol
Old Nov 1, 2010 | 08:16 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Sounds like the solenoid or starter is the culprit. With a screw driver try jumping the solenoid posts (located near the battery on most) to see if the starter motor engages. If so I'd suspect the solenoid is bad. If not, probably a starter motor problem. Had the same issue intermittently with my 07 and turned out to be a sticking brush in the starter housing. If you suspect the starter motor, try tapping on it with a screw driver to see if it'll work. (sometimes you get lucky) Also check all electrical connections.
Old Nov 1, 2010 | 11:34 AM
armyrepsol's Avatar
Is this a big pain in the butt to fix or do? am i best off to bring it to the dealer to get fixed?
Old Nov 1, 2010 | 12:24 PM
Depends on how handy you are. The solenoid only takes a couple minutes to change. The starter on the other hand is a little more time consuming but not a difficult job. Just need a little patience.
Old Nov 1, 2010 | 02:30 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. first question we always ask is the battery 100% charged? if so, as mentioned w/ the key on jump the 2 big cables on the solenoid(just follow the battery cables back to it) and if the starter engages the engine you know it's a bad solenoid. if not then the starter is the issue. if you are not mechanical inclined i would let a dealer fix it. good luck.
Old Nov 3, 2010 | 01:00 AM
MrMarty51's Avatar
"Usually" a series of clicks in rapid succesion is a low battery,try this,turn on the switch/turn on the headlamps/now twist the ignition into start mode while watching the headlamps,did the headlamp go dim??? if so then you have either a bad battery or a discharged battery.
Put the battery,if in a low state of charge on the charger for twentyfour hours at two amps then see if it starts,if it has the same symptoms then remove the battery and take it to a partshouse or to Your polaris dealer and have it checked,if bad replace the battery.
DO not operate Your maachine with a bad battery,it can burn out the stator and then You will have problems.
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
Raccar1
Jun 18, 2015 02:17 AM
1000gade
May 27, 2015 12:37 PM
