110cc Gio will not start
Old Nov 3, 2010 | 09:47 AM
wickedkawi's Avatar
Default 110cc Gio will not start
Hello..i have a gio 110cc mini beast and i cannot get it going.i am a dealer so i have checked the obvious things like fire and fuel delivery. the only thing i can think is perhaps the oil grade 10w-40 may be to thick not allowing for the machine to turn over quickly enough? im baffled with this one...all kill switches are working properly..fuel **** is set to on. any help would be much appreciated.
Old Nov 3, 2010 | 10:15 AM
aircube's Avatar
Its turning over slow?
Whats the Batt voltage while its turning over?
10-40 would't stop it from turning over unless its like 0 deg F in winter. That would slow it down.
Old Nov 3, 2010 | 11:12 AM
wickedkawi's Avatar
Default reply
i got it running...new battery didnt have the capacity to turn over the engine fast enough.anyhow i hooked an old car battery to it and replaced the 10-40 with a synthetic amsoil 4 stroke oil then i adjusted the idle screw on the carb...it was turned in way to far..so i backed it off considerable..maybe a full turn and away it went...go figure
Old Nov 3, 2010 | 11:46 AM
aircube's Avatar
No fuel in the idle circuit and low batt power, that'll prevent it from starting for sure.
yea, a lot of the batts that come with these machines are not very good. Even the brand name ones of the same size and brand new are not really enough batt in really cold weather, or after a long drain.
I have found over the years that I have to replace my snowmobile, tractor and quad batts every year or two. third year is always a gamble, esp if its cold, or you don't use it at least 1-2 a week.
Glad you got it going, perhaps tune the needles now that its running
Old Nov 3, 2010 | 12:10 PM
wickedkawi's Avatar
Default thanks!
Hey thanks bud...so yeah..about the needle setting ...what would you reccomend?
Old Nov 4, 2010 | 10:50 AM
aircube's Avatar
A reasonable place to start with the low speed mix is 2 turns out, most will run at that setting but you will have to tune it from there to be optimum.
Heres a great read to learn how to tune
If it is running fairly well right now, make sure you count how many turns out it is. Even an 1/8 of a turn makes a diff in throttle response.
http://forums.atvconnection.com/chin...-sunl-etc.html
Old Nov 5, 2010 | 04:00 PM
Jaster94's Avatar
Default quad batteries
don't know what brands of replacements batteries y'all use, but after trying several different ones through the years, i've found that the everstart brand, yeah i know: walmart(yuck), has outperformed everything i've tried. i've had my quads out in the cold, whether winter riding or out hunting(sitting overnight when it's 20 degrees or colder, they start up fine. yeah, mine have even sat in the garage for a month without starting and they've fired up fine upon demand. anyway, like in my signature, there's my 2 cents on batteries..........
p.s.
my everstarts are usually 4 yrs old before i replace them. don't trickle charge them until they're about 3-3 1/2. that's been my average.
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
Dame0927
Oct 29, 2015 10:13 PM
Spokes
Jun 22, 2015 08:02 AM
kevbowe
Jun 1, 2015 01:17 AM
1000gade
May 27, 2015 12:37 PM
