Sport Quads Discussions on sport quads.
Honda 700XX straight axle?
Old Nov 4, 2010 | 07:11 PM
kevin773's Avatar
Default Honda 700XX straight axle?
I think that Honda would have a winner if they made a 700XX with a straight axle. It would be more capable of competing with the raptor 700. Thoughts?
Old Nov 4, 2010 | 07:50 PM
TLC's Avatar
TLC
The 700XX is 109 lbs heavier than a 700 Raptor. It really was not meant to be a race sport ATV, but more a recreational Sporty ATV.
People looking for a ATV like that are not out to do jumps, but want Ground Clearance, a smoother ride and no chain to constantly fool with. Both of which a IRS has the advantage over a SRA with chain drive.
The 700XX is more closely related to a Can Am Renegade and Kawi KFX 700 then a Raptor.
If some one wanted serious racer Honda ATV they would get a 450R.
I Trail ride with a guy who hates Utility ATVs and has a 500 Scrambler,but he does not like the wimpy 5" ground clearance and mantaining the chain. The 700XX would be the ATV for him and many others.
Old Nov 4, 2010 | 08:15 PM
kevin773's Avatar
Well, Polaris makes an outlaw irs/straight axle, they seem to sell ok, Maybe if Honda put the 700 motor into a 450r-type frame :/
Old Nov 4, 2010 | 08:19 PM
TLC's Avatar
TLC
I always said Honda should put there XR650R motorcycle motor in the 450R ATV frame.
XR650R is nice
Old Nov 4, 2010 | 08:25 PM
kevin773's Avatar
Same with Can-Am, Ithink they should make an updated Ds-650...
Old Nov 5, 2010 | 06:44 AM
unit6666's Avatar
The 700x honda is a beast.. It does about 77-80 mph stock.. and it is chain drive..
Old Nov 5, 2010 | 07:40 AM
It is a chain drive. Like the Polaris Outlaw IRS the chain is a good height up so it probably wouldn't get the kind of abuse a regular straight axle chain does. My own thought on the 700xx is that it is great in the kinds of conditions where you have rocky and/or rutted trails to clear obstacles like the Outlaw IRS. The 700xx isn't as stiffly sprung as the Outlaw though and probably not quite as good in corners. A straight axle version would rail in corners and would also lose some of the weight of the IRS system. Just random thoughts.
Old Nov 5, 2010 | 09:03 AM
TLC's Avatar
TLC
A chain on on a IRS ,that must suck. A chain you have to lube and re tighten every so many rides,a shaft or direct drive you don,t even think about it for 3 seasons of riding.
Old Nov 5, 2010 | 12:41 PM
kevin773's Avatar
Yes, it is a chain drive, but the final drive is shaft..
Old Feb 25, 2011 | 11:56 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
Kevin-
It is a chain drive...there is no "final drive" The rear sprocket connects to the axle hub directly, there is no additional gearing like there would be with a differential or final drive. From there there are just IRS axle shafts. Principle is the same as a SRA, just with pivoting axles
Asaran
Oct 8, 2015 11:14 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
HondaR24
Jul 16, 2015 10:45 AM
Rider252
Jul 6, 2015 03:37 PM
