Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
CVT Transmission / Manual
Old Nov 9, 2010 | 03:34 PM
vettebill01's Avatar
Question CVT Transmission / Manual
Howdy folks. I currently have a 2001 honda rancher 350 es, 2x4. I saw a 05 YAMAHA KODIAK 400 4X4 on craigslist. Am considering upgrading to 4x4. Personally, I prefer the manuals (semi automatic) however i may go to automatic. Are the cvts less efficient since the engine generally tends to rev higher? also, does turning the extra axle when you are in 2wd burn more gas? Any feedback is appreciated
Old Nov 9, 2010 | 03:54 PM
kevin773's Avatar
Greetings! If anything, my guess would be that a cvt would burn less gas because you are technically always in the "right gear" so to speak. Neither is beter than the other, it just takes some time getting used to the switch
Old Nov 9, 2010 | 04:27 PM
i see. I rode a cvt before, and it seemed to me that i had to give it more gas to get it to want to accelerate, perhaps however you could be right in saying that they are the same
Old Nov 9, 2010 | 06:10 PM
kevin773's Avatar
well, actually it depends. On a cvt machine, the RPM level is directly relative to the speed, unlike a manual. So, on the low end, it probably uses less fuel, and on the high end, it probably uses more than a manual cruzin low RPMs in a high gear.
Old Nov 10, 2010 | 11:14 AM
TLC's Avatar
TLC
There all clutch different,it depends on which one you rode. My first 3 ATVs were manual 5 speeds, a 250 Moto4 ,350 Big bear and 450 Foreman, I would not go back,constantly shifting gears on the trail to be in the right power band is a annoying chore after awhile.
Maybe a 5 speed on a sporty race ATV makes sense but not on a Utility.
Old Nov 10, 2010 | 01:07 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
Another thing, and I don't know why, is the Yamaha's have a tendency to get a little worse gas mileage. I have had a Kodiak 400 and a 450 and that seemed to be the case. Not sure if it was the gearing or the carb. I loved both machines though. I think you will love the upgrade though. The extra weight on the front helps keep the front down on hills too. Just another added thing!
Old Nov 10, 2010 | 02:42 PM
yeah. i personally prefer shifting, and i dont do anything intense with em...i might stick with the rancher es
Old Nov 10, 2010 | 02:46 PM
unit6666's Avatar
shifting is pretty fun.. I have a rancher same as yours and i have a rincon.. I always choose to shift the rincon when I ride it..
Old Nov 10, 2010 | 02:47 PM
yeah man, im also thinking, do i really need the new quad you know? i think its just the idea of gettin a new one
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
WilliamBos
Sep 22, 2015 04:07 PM
