Frontend Drag in Four Wheel Drive
Old Nov 29, 2010 | 01:08 AM
blackwaters's Avatar
Default Frontend Drag in Four Wheel Drive
My dad has a 2007 Polaris Sportsman HO 4x4. It has developed drag in the front end with a noise as well. It only happens in four wheel drive and when coasting to a stop or break to a stop. In two wheel drive it doesn't do any of this. This started last Spring with no noise and now has got worse and developed a noise. When you are on the gas in four wheel drive there is no sound and no drag everything works fine and pulls hard and true. Just wondering if anyone has experienced this and if it is a problem??? Would like to fix it and stop this before something bad or worse happens. Your replies are much appreciated.
Old Nov 29, 2010 | 10:19 AM
8fitty's Avatar
Does it have ADC? Maybe change the fluid for the ADC and see if that helps
Old Nov 29, 2010 | 01:09 PM
Do you know where the ADC fluid reservoir is located on a 2007 Polaris Sportsman 500 HO? Also, how do you change that?
Old Nov 29, 2010 | 09:51 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
If it has ADC it may be time to change the front drive fluid. Just be sure to use the proper fluid for the bike. Bikes with ADC requires demand drive plus for the front drives.
Old Nov 30, 2010 | 09:55 AM
Kerbbirds's Avatar
Think adc resevoir is under front by radiator cap
Old Nov 30, 2010 | 03:19 PM
So is there anything I need to know to change it?
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
cody500ho
14
Aug 14, 2015 05:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
HondaR24
Jul 16, 2015 10:45 AM
