Metal pieces drained from 2003 SP 700 Tranny
Old Nov 29, 2010 | 10:37 PM
PatsPolarisPage's Avatar
Default Metal pieces drained from 2003 SP 700 Tranny
Can anyone tell me what these metal pieces that came out of my tranny when I drained the oil are? Are they the pieces of the wave springs, that go between the engagement dogs?
They were a bent up when they came out, so I straitened them a little.
Attached Thumbnails Metal pieces drained from 2003 SP 700 Tranny-img_6625-large-.jpg
Old Nov 30, 2010 | 09:52 AM
Kerbbirds's Avatar
If you look at the parts diagram on ronnies .com it looks like #48 which is a shim
Old Nov 30, 2010 | 02:18 PM
Yeah maybe, I thought it would be hard for the wave spring (#26) to get all the way down to the drain plug.
That shim is up against a bearing, wonder if the bearing would be damaged now? Can I pull the side case off without disconnecting the drive shafts. By just taking the bolts out and sliding it over the shaft? Then I could see if is the shim or not.
Attached Thumbnails Metal pieces drained from 2003 SP 700 Tranny-gearcase-exploded-view.jpg
Old Nov 30, 2010 | 05:47 PM
Kerbbirds's Avatar
Gotta tear it apart, fun fun
ReconBayou
Oct 31, 2022 05:37 PM
Oct 10, 2015 10:20 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Hw00d
Sep 10, 2015 08:53 AM
toonces
Sep 5, 2015 01:14 PM
