Winch Amps?
Old Nov 30, 2010 | 11:50 AM
bcdudley's Avatar
Default Winch Amps?
I have a Polaris / Warn Winch that I am rewiring. I was wondering if anyone has any idea how many amps a winch will pull. The winch is whatever came on a 2000 Sportsman 500. I am guessing it is about 2500 lbs, but I could be way off.
I need to know because I am putting a relay on and I need to know how big it needs to be. When I got it many years back, it had a Ford starter solenoid as the relay, but those seem to wear out about every 3-4 months. I have a 30 amp relay, but I don't think it is anywhere near heavy enough to run the winch.
Thanks
Old Nov 30, 2010 | 03:48 PM
james feeney's Avatar
If you search the warn site enough you should find the amp draws and line pulls.
You need a heavy duty contactor to use as the relay. I have just refurbished an old A2000 Warn and used a new Warn contatctor (part no. 63070). They are available elsewhere, non branded, for around $30.
Here you go as an example
Warn Industries - Discontinued Winches: 2.5ci
And the aftermarket contactor
Amazon.com: KFI ATV Replacement Winch Electrical Contactor: Automotive
Hope this helps
JF
Old Nov 30, 2010 | 04:13 PM
bcdudley's Avatar
Thank you. I had just purchased something similiar from Amazon about 5 minutes before you posted that. I got
Amazon.com: WINCH MOTOR REVERSING SOLENOID CONTACTOR RELAY 6 Term: Automotive
Along with
Amazon.com: ATV Mini Rocker Winch Switch / Handlebar Remote Control: Automotive
Hopefully it will work out.
As I said, I have been using a Ford starter solenoid for the past 5 years along with one of these
http://www.warn.com/atv/accessories/...000_switch.jpg
Zip tied to my front rack.
I think the new set up will be much better. I also completely tore apart my Winch last night and cleaned up the insides real good. I also greased up all the gearing in there and sealed it up the best I could with RTV.
I had a problem with overheating, but I think it may have been caused by the Winch setup. Between the bad solenoid and mud inside the motor, I think it was drawing the power down so low that the fan couldn't come on high enough.
Old Dec 1, 2010 | 12:38 AM
You may want to look at an uprated battery also. I'm opting for an Odyssey PC680. I know in the trucks it makes a huge difference. Especially when my stator is only producing 8 amps.
All the best
JF
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
