2001 325 Trail Boss Trans Problem
Old Dec 2, 2010 | 07:13 AM
ZONER727's Avatar
Default 2001 325 Trail Boss Trans Problem
It will go into forward and reverse but in forward it seems to be stuck in low.It is a VS transmission,Fluid is correct ,no noises other than hi rev in forward gear.Any suggestions?Thanks
Old Dec 2, 2010 | 07:37 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
When you say low, you mean it will only go so fast? Just to be sure you know, it only has 1 forward and 1 reverse "gear".
Have you checked the belt and clutch out yet?
Old Dec 2, 2010 | 05:04 PM
ZONER727's Avatar
Yes .It will only go so fast now.About half the speed of the day before when it was ridden.I know it does not have "gears" but it seems like it is stuck in low.Only the forward was affected.But I appreciate you responding.
Old Dec 2, 2010 | 05:12 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
does it seem like your taking off in high gear( meaning if it was a standard,yes i know it's not but using it for a refernce,and you were starting in 3 rd gear in stead of first) then it might be either the belt being bad or the secondary clutch buttons are worn completely out.
Old Dec 2, 2010 | 05:53 PM
ftwflh's Avatar
Take the secondary (back clutch ) apart and check the ramps and helix
Old Dec 3, 2010 | 09:54 AM
EPIChad's Avatar
I agree with Stendori and FTWFLH
njrider64
Jul 4, 2017 01:40 AM
wildbill59
Jun 20, 2015 02:26 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
