05 sportsman awd engages in foreward but not in reverse
Old Dec 25, 2010 | 02:35 PM
dougpeck's Avatar
Default 05 sportsman awd engages in foreward but not in reverse
i have a 05 sportman that when i am plowing the awd doesnt engage in reverse i spliced the ground wirer from the speedo that didnt work going to change the trans fluid but today is christmas day polaris dealers are not open is there any other fluid i can use and is there anyone that might know how to fix the problem
Old Dec 25, 2010 | 05:29 PM
Kerbbirds's Avatar
does the speedo show R when in reverse? if not its the trans switch, you are pushin the over ride button ,right?
Old Dec 25, 2010 | 07:08 PM
dougpeck's Avatar
Default yes and yes
it shows r when in reverse and i am pressing the override button if i dont press the override button it backfires it also flashes slow when in reverse and not engaging
Old Dec 26, 2010 | 08:19 AM
Kerbbirds's Avatar
Is the battery fully charged? you say you spliced a ground wire, Why was it broken?, awdswitch lite up in reverse?
Old Dec 26, 2010 | 12:29 PM
dougpeck's Avatar
on another fourum they said that the awd is grounded through the speedo so if the speedo isnt working the awd wont engage they said to splice in a ground wire to try to fix the problem ya the awd is lit up it just doesnt engage except in foreward
Old Dec 26, 2010 | 05:28 PM
Kerbbirds's Avatar
ah speedo isnt working, some had ecm recall , is yours one? 05 what? hard to diagnose without all info, start from the beginning and tell me your story
Old Dec 28, 2010 | 12:49 PM
TLC's Avatar
TLC
Maybe roller cage . ATV Frontier - ATV Forums, News, Reviews, Chat, Maps, Classifieds and More › Forums › Branding Iron › Polaris › no AWD in reverse
My brother rode his all day after we discovered the problem. Had 4wd in high and low, just not in reverse. The rollers would engage normally in forward. The Override button worked fine and we got the flashing "SLOW" as is normal, just no 4wd in reverse.
The dealer checked everything electrical before disassembling the Hillard and finding the cage cracked.
I yanked the front diff out yesterday and popped the top off and took a look inside. The cage was cracked in numerous places and it probably was on it's last leg's working in forward gears too. I took it the diff to my dealer and they are going to try to put the repair through under "good will repair". If they don't repair it under warranty I'll just take my diff back and order the cage and install it myself. Thank's of all the suggestion's but everything i done kinda leaned to that front cage being pooched......and it was.
_________________
Old Jan 1, 2011 | 09:52 AM
dougpeck's Avatar
Tradebit Download Center
05 400 and 500 sportsman repair manual available for d/l until 1/4/2011
kerbbirds it started not engaging only once and a while now not at all in reverse i put the speedo in diagnostic mode and everything checks out so i believe i have eliminated a electrical problem i changed the fluid in the front and back still dont work i dont know if i should go any further or bring it to the shop its my dads 500 and i would hate to make things worse im thinking the front diff is my next step to find the problem
Old Jan 1, 2011 | 10:29 AM
Kerbbirds's Avatar
John deer part #s
Roller kit MIA100666
Cage kit #Mia100667
seal kit#Mia10654
Last one I did was around $100
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 10, 2015 12:42 AM
