stater solenoid
Old Dec 28, 2010 | 07:01 AM
Mikka's Avatar
Default stater solenoid
Anyone, ever experienced difficulty with their starter solenoid in the sense that you have to click it several times before it goes all the way and makes good contact to engage the starter? Just like trying to start the engine with a dead battery.
Mine is an 08 sporstman/800 and if it has not gone for a while, say overnight, it will contact only after many tries and the battery is alway fully charged as I keep it on a battery tender. When the engine is warm, it is not an issue.
Just wondering what is the cause.remedy for that?
Old Dec 28, 2010 | 07:15 AM
Kerbbirds's Avatar
take the battery cables off the selenoid, check the nuts under the cables, Ive seen them come loose
Old Dec 28, 2010 | 09:06 AM
papa hogg scoot's Avatar
Loved
Community Favorite
May have starter bendix not engaging from dirt or water, IMO i would probe the starter wire with an test light.. take test light and clip to ground then probe starter wire with pick, then push starter button while probe is in wire if the probe lights up while button is pushed then your solenoid is working, then problem is below the probe not before, [starter brushes or sticking bendix].Good Luck..
Old Dec 28, 2010 | 09:28 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
+1. If solenoid is ok, most likely sticky brushes. Had that problem with my 07 after some moisture got in there. Take apart and clean and lube.
Old Dec 28, 2010 | 05:20 PM
Overdrive's Avatar
The vast majority of the time it is your starter brushes causing this problem.
Joe454
Nov 20, 2020 01:19 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
Jackg17
Sep 26, 2015 09:30 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
