Whats the trick to removing secondary Clutch
I have a Polairs Sportsman 600. I need to remove the secondary clutch was wondering what the trick is. Can I get a longer bolt like the do when removing the primary clutch?
Thanks
Thanks
usually they pull right off , some get alittle stuck, I take a pry bar and gently pry out on the backside and hit the front with a rubber hammer, squirt penetrating oil in the bolt hole and down the back of clutch, work yor way around the clutch with the pry bar and ruubber hammer or dead blow hammer and they will usually come off, they make a puller there should be one on e-bay
Like they said they should just slide off. If they dont spray pentrating fluid in the center hole of the clutch where the bolt came out and let it soak. You can LIGHTLY tap with a rubber hammer but it doesnt come off then use the clutch puller. EPI makes one, part number SCP-1 that sells for 24.95. Works on all Polaris ATVs 85-09.
www.epiperformance.com
