05 Brute won't start
Old Dec 30, 2010 | 10:40 AM
guido163's Avatar
Default 05 Brute won't start
Hey guys,
I've got an 05 650 that I've had since new. It's a great machine. Now yesterday I pull it out of the garage and fire it up. Runs OK. Take it for a cruise and it only tops out at about 35 mph. It killed once on the way back as well. Now, It won't start. Air cleaner is off and the plugs are Ok. I gave it a shot of carb cleaner and still won't fire. Always ran fine til now. Any ideas?
I'm thinking maybe carb cleaning as its been sitting for about a month.
Old Dec 30, 2010 | 04:40 PM
player9772's Avatar
make sure a wire didnt rattle loose and off the either of the 2 coils, happens kinda often
Old Dec 31, 2010 | 07:27 AM
papa hogg scoot's Avatar
Loved
Community Favorite
IMO if you shot with carb cleaner and still not fire up its prolly not firing to ignite cleaner or compression left? I would check fire and then compression, then fuel last, fuel system needs them two thing to work also...Check plugs also.
Old Jan 1, 2011 | 09:21 AM
guido163's Avatar
Stupid question?? should these machines run without a battery??
Old Jan 5, 2011 | 10:04 PM
Loved
Community Favorite
Not long todays atvs need 12volts most of the times to run correct....Do you not have an battery on it?
Old Jan 6, 2011 | 02:52 PM
guido163's Avatar
Funny what a couple new plugs will do.....Fires up now, but won't run right. It will run with the choke on and then when you take it off it will idle. Put in gear and give a little throttle and it kills.
I had the battery off to charge it. Seemed to turn over slow, but it's got 14 volts. Time for a new battery maybe.
Old Jan 7, 2011 | 04:38 AM
oral1139's Avatar
_____________________________________
Old Jan 7, 2011 | 05:04 PM
guido163's Avatar
I can only imagine what that reply said...
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
