2005 kodiak starting question
Old Dec 31, 2010 | 07:16 AM
danpalms15's Avatar
Question 2005 kodiak starting question
Hey guys so my Kodiak doesn't start good.It seemed to start fine before with this kit in but i took the carb apart just to check it out before winter. It has a complete new carb kit in from Shindy (good quality) and the float is adjusted to 13mm from the gasket service to the very top of the float. It takes at least a good 1-2 minutes on choke before it will idle.(this is about 25 degrees out and sitting about 3 hours after running) also when it does idle the idle is a bit choppy but no to bad kind of goes a little low then high and so on..the other thing i noticed is if i adjust my pilot screw it does nothing, if i close it it will turn the engine off but it will idle the same from .5 turns out to over 3 turns out, no change in idle speed. Does anyone have any suggestions? It almost seems when adjusting the float height the float is lower than the pilot screw (maybe pilot screw is hardly getting gas) let me know!
Thanks
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
hoopduerr
Jun 10, 2015 03:00 PM
1000gade
May 27, 2015 12:37 PM
