idle question
Old Jan 1, 2011 | 11:39 AM
icemanec63's Avatar
Default idle question
i have a 2007 350 griz it only idles if the choke is on a lil bit.does this sound like i got dirt in the idle jet
Old Jan 1, 2011 | 10:13 PM
Ratchee's Avatar
Default choke
just put it full choke and let it idle until it dies.. like 2/3mins and then take the choke off completly and start it up and i should idle fine. let me know if this works for you.
Old Jan 2, 2011 | 10:11 AM
icemanec63's Avatar
thanks for the reponse, ill try that the next time i start it up.i put some seafoam in it ,maybe it will help
Old Jan 3, 2011 | 04:46 AM
JSJ's Avatar
JSJ
Your slow jet is pluged pull the carb and clean it with a small stiff wire you might get lucky with carb cleaner but usally they varnish up pretty bad. Just don't get the carb clear on any rubber gasket it will ruin them. And don't drill it out or guage the jet out use a wire from a wire brush to clean it out.
Old Jan 3, 2011 | 09:54 AM
Kerbbirds's Avatar
ditto on the PILOT jet, small wire, carb cleaner, compressed air
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
house1
Aug 9, 2015 10:49 PM
momma's bike
Aug 6, 2015 09:49 AM
ranvette
Jul 12, 2015 06:34 AM
