Hillard clutch Question
Old Jan 1, 2011 | 08:54 PM
randyneff6971's Avatar
Default Hillard clutch Question
Is it possible that the spring around the hillard can get tighter if the quad was run without demand drive fluid?
Old Jan 2, 2011 | 01:33 PM
94harley's Avatar
I suppose if it got moisture in it and rusted it may not stretch out anymore. Other than that i don't see how it could get tighter.
Old Jan 2, 2011 | 05:00 PM
No there was no moisture, I have never had a problem with taking this kind of hub apart and putting them back together they are pretty simple and straight forward. I was unable to work on it today so tomorrow I have to take the other side apart and change out the seals as well. What I`ll do is take that hillard out and veiner caliper compare the 2 then put the one that I know is working on the side thats giving me the problems. Its got me baffled but i know there is a solution and I`ll find it.
Old Jan 3, 2011 | 06:35 PM
MECHANIKE's Avatar
sometimes the rollers and /or hubs wear down enough where they do not clear the cage or engage the hilliard hub race.measure inside diameter of hub race also.
Old Jan 3, 2011 | 07:17 PM
Turns out it was a combination between the armature place and the housing spring around the hillard. Works like new now, these systems are so easy i just wasn`t seeing the problem until I switched sides. thanks.
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
