Xplorer 300 Top End
Old Jan 11, 2011 | 02:09 PM
jetmecanic's Avatar
Default Xplorer 300 Top End
The 300 gave up the ghost in the southern snow! Can I get the head and cylinder off without too much trouble or just easier to pull engine?
Thanks in advance!
Old Jan 11, 2011 | 07:08 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Yes. It is not bad at all. I highly recomend a Wiseco piston as a replacement because they are forged.
Remove the head bolt, head then slide the barrel up over the piston and off the machine. Cover the bottom end of the machine with shop towels to keep trash out of the exposed engine. Get a pic and remove the wrist pin bearing clips, then push out the used piston (now fancy ash tray). Buy a new wrist pin bearing and piston and ring. I bored the cylinder .010 over and bought the correct size Wiseco piston to match the bore.
Easy job for an A&P.
Old Jan 12, 2011 | 06:07 AM
jetmecanic's Avatar
Weedy
Outstanding! Thanks for the info.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
