dies going into reverse
Old Jan 13, 2011 | 10:48 PM
rickybobby01's Avatar
Default dies going into reverse
I have a 1998 xplorer 300 I sometimes dies when I put it into reverse unless I hold down the overide switch. Any ideas? I had an engine change from the previous owner. Starter also seems to be bad.
Old Jan 14, 2011 | 05:59 AM
ftwflh's Avatar
Find and unplug the black wire on limiter box
Old Jan 14, 2011 | 02:08 PM
Overdrive's Avatar
That should do it.
Old Jan 14, 2011 | 02:11 PM
Overdrive's Avatar
I traded for a 98 a while back. It only had 600 actual miles on it. Original tires and it looked like it just came off the show room floor.
The first thing I did was unhook this wire. I knew it would save me a lot of problems later on.
Old Jan 14, 2011 | 02:56 PM
Thank you that fixed it. What exactly does the overdrive switch do?
Old Jan 14, 2011 | 05:38 PM
ftwflh's Avatar
it is a safety feature that causes it to cut out when backing up so you dont fly backwards like a dummy.
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
poutlaw525
Sep 9, 2015 03:19 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
