CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Winch Problem
Old Jan 16, 2011 | 04:59 PM
dmax02's Avatar
Default Winch Problem
Plowed a little snow this morning. Pushed the out button to drop the blade but nothing happen. It will come in with the handle bar and the remote control switch but neither will run it out. I have a CD service manual but it doesn't cover the winch. There has to be a switching relay somewhere. Can someone help? Thanks. Frank
Old Jan 16, 2011 | 10:04 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
Default What Brand?
I had this same issue with my warn 1500...even with the weight of the plow hanging there the winch would only run in. I took the winch off of the quad and completely tore it down...it had water in the gears that was freezing. I regreased everything and put it back together and have had no issues since. You may also follow all of your wiring back toward the battery and inspect all wiring and connections. Let us know what you find. Good Luck. Mudslinger2
toonces
Oct 19, 2015 02:21 AM
user493
Aug 13, 2015 12:54 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
